Author Topic: TortoiseSVN in EA 9.2?  (Read 4589 times)
cbear2339
« on: December 23, 2011, 02:31:42 am »
Does anyone know if this statement from Sparx on TortoiseSVN (v8) is still true in EA 9.2?
"Enterprise Architect cannot use TortoiseSVN to communicate with the Subversion server; it must use the Subversion command line client."
Thanks in advance!
Chana
Jerry Gray
Re: TortoiseSVN in EA 9.2?
« Reply #1 on: April 03, 2012, 11:56:36 pm »
This is true.  EA uses the Subversion command line client.
However you can use TortoiseSVN outside of the EA environment to do things like browse the repository, build new working directories, etc.  Essentially everything in the TortoiseSVN command set.
Command-line client is for EA.
TortoiseSVN is for Windows Explorer.
Cheers -  :D
Bill McCracken
« Reply #2 on: April 18, 2012, 08:20:41 am »
and still true for 9.3.
« Reply #3 on: April 18, 2012, 05:54:33 pm »
What's the problem with that? Tortoise itself also uses the command client under the hood. Are you afraid of to much disk space to be wasted?
