Author Topic: LOST LINKS BETWEEN CLASSES  (Read 3854 times)
IBS
« on: April 25, 2012, 05:08:40 am »
Hello We are in need of assistance due to a problem that occurs in our environment.
Our scenario is as follows:
• We work with EA in a team of six analysts.
• Do not use the database to control the elements of the EA.
• We use TortoiseSVN to access control and versioning.
The problem is this: we often miss links between classes or even links that had been deleted reappear.
Has anyone experienced this problem or have a tip that can help us?
Already thank you for your attention!
Re: LOST LINKS BETWEEN CLASSES
« Reply #1 on: April 25, 2012, 07:07:18 am »
This is unfortunately a non-trivial case. For exactly that reason we have stopped using version control and switched to using a central database with locking (require user lock to edit) and nightly snapshot.
(I should pinpoint my post where I described our odyssey)
[edit]: here it is: http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1319704883/6#6
« Last Edit: April 25, 2012, 07:27:40 am by qwerty »
