Author Topic: Slow access with RaQuest at MS SQL Server  (Read 3555 times)
Chaft
« on: September 10, 2012, 11:29:18 pm »
I use EA and RaQuest with MS SQL Server and I encounter some problems.
When RaQuest starts, the downloading of the data from the data base is a bit log (5-6minutes).
Whereas when EA starts, the load is very fast (almost imediate).
Is it normal or something is going wrong ?
Thanks  ;)
umesan
Re: Slow access with RaQuest at MS SQL Server
« Reply #1 on: September 11, 2012, 05:18:48 pm »
Thank you very much for using RaQuest.
Taking some time to open a RaQuest file is an issue of RaQuest at the moment.
Enterprise Architect displays only a part of Project Tree when opening a file. Whereas RaQuest displays List at file opening.  This causes RaQuest to take some time to read a lot information from a project when opening a file.
We will improve RaQuest to open a file more quickly.
However, the slow opening may be caused by some other reasons, so please could you take a log by the following steps and send it to RaQuest support ([email protected])?
- Launch 'Start -> RaQuest -> Execution Log Viewer'
- Start RaQuest
- Open a file
- Store the detail information by 'File -> Save As' of Execution Log Viewer
Chaft
« Reply #2 on: September 11, 2012, 10:11:27 pm »
Ok thanks, I will contact the support with the log file  ;)
