Author Topic: Action code in state diagrams - XMI export  (Read 4297 times)
Peter Mueller
« on: September 22, 2012, 01:27:08 am »
it is possible to specify code for the entry/exit/do action code using the behaviour property. But code written in the field "initial code" which nicely provides syntax highlighting is not part of the exported XMI. Ok, it is but in the part which specifies graphics and other stuff.
On the other hand there is a second code entry field which is correctly exported in the XMI structure. But this does not provide syntax highlighting. Strange!
Is this a bug or a feature? Is there a way to change this via configuration?
With best regards,
Peter
Re: Action code in state diagrams - XMI export
« Reply #1 on: September 22, 2012, 06:15:57 pm »
I guess it's a "feature". You should ask Sparx support directly.
