Author Topic: Subversion repo and Linux (via wine)?  (Read 6773 times)
Vitor Sakaguti
« on: December 05, 2012, 01:12:12 am »
I just installed EA on Linux via wine and this project I need it for uses a subversion repository. When I try to configure it, the dialog only gives me the option of searching for a "SVN Exec" file, I cannot select the /usr/bin/svn file.
How can I accomplish this on linux?
Thanks!
Makulik
Re: Subversion repo and Linux (via wine)?
« Reply #1 on: December 05, 2012, 01:43:45 am »
You'll need to install an appropriate (Windows!!) SVN client in the EA wine bottle. E.g.  Slik SVN would do well.
Günther
« Last Edit: December 05, 2012, 01:44:30 am by Makulik »
Vitor Sakaguti
« Reply #2 on: December 05, 2012, 10:18:20 pm »
Yeah, I was afraid that would be the only solution... After struggling a little bit with TortoiseSVN I got it working.
Thank you!
Makulik
« Reply #3 on: December 05, 2012, 10:47:59 pm »
Tortoise SVN is not a suitable command line SVN client for use with integration in EA.
Best regards,
Günther
Vitor Sakaguti
« Reply #4 on: December 05, 2012, 11:15:51 pm »
TortoiseSVN 1.7 will optionally install a command line. I'm using it and it works, but I'm not doing anything very complicated. Actually, I just update to get the latest reviews from other tem members.
Should I expect anything not to work properly? Everyboy else here is using TortoiseSVN as well...
Thanks!
Makulik
« Reply #5 on: December 06, 2012, 02:46:18 am »
That's a newer version of Tortoise SVN I've never tried, seems that even this command line option is new. Slik worked (and works) fine for me and is also free.
Best regards,
Günther
