Author Topic: Advanced-->Make Composite missing in EA 9.3 Pro Ed  (Read 4119 times)
Jayanta Chakrabarty
« on: December 25, 2012, 07:39:32 pm »
I am using a registered version of Enterprise Architect 9.3 (Professional).
My biggest problem is, I am not getting the Advanced|Make Composite menu in context sensitive help upon clicking right click on the element (use case, class whatsoever) in any diagram. Please help me, I have become fed up after trying for the last 24 hours.
Jayanta
Re: Advanced-->Make Composite missing in EA 9.3 Pr
« Reply #1 on: December 26, 2012, 10:26:01 pm »
It might be a View/Workspace/Commands issue. Check that Complete is set.
Aaron B
« Reply #2 on: January 07, 2013, 12:00:29 pm »
What exactly are you seeing in the right-click menu at the moment?  If you are only seeing a list of element types (i.e. as seen in the toolbox) when you right-click in the diagram, it's possible that Windows StickyKeys might be active and holding in either the Shift or Ctrl key.
Otherwise, as qwerty suggested, you might have selected a Command Set which has hidden this menu option.
Open: View | Workspaces and Commands > Commands.
To make all available menu options visible, select the "Complete" command set.
« Last Edit: January 07, 2013, 12:03:14 pm by AaronB »
« Reply #3 on: January 07, 2013, 06:40:12 pm »
I just figured out that this function has completely changed in version 10.
Now there's a new context menu "New Diagram" that allows you to either create a new composite structure diagram, or select a diagram to be used a the composite diagram.
That is pretty cool, no more explaining the 5-step trick to link an existing diagram as the composite diagram  ::)
