Author Topic: Inconsistent behavior with sequence diagrams  (Read 3520 times)
« on: May 01, 2013, 03:01:24 am »
If you populate a SD (inside an interaction element) EA behaves habitually inconsistent.
- Drag an actor as instance onto a SD
  -> it appears as stickman with name :<actor>
  -> the browser shows a lifeline symbol in place labeled also :<actor>
- Create an Actor element with the toolbox
  -> it appears as stickman (with no name as we delete that)
  -> now we classify it with our <actor>
  -> the classification is [highlight]NOT[/highlight] shown
  -> the browser shows a stick man also with [highlight]NO[/highlight] classifier
- Drag a class as instance onto the SD
  -> SD looks fine
  -> the browser shows an [highlight]object instead of a lifeline[/highlight]
- Drag a component as instance onto the SD
  -> the SD looks fine
  -> the browser creates an [highlight]object instead of a lifeline[/highlight] and does [highlight]NOT[/highlight] put it inside the interaction
  -> trying to move the instance into the interaction results in a [highlight]The requested move is not supported[/highlight]
Should I report that as bug or simply resign?
« Last Edit: May 01, 2013, 03:05:55 am by qwerty »
Re: Inconsistent behavior with sequence diagrams
« Reply #1 on: May 07, 2013, 07:10:31 am »
Nothing to say?
