Author Topic: Links not instances  (Read 4195 times)
markl
Links not instances
« on: February 22, 2013, 12:09:53 am »
Hello
In v9.3. How can I ensure that only links are created of objects when dragging onto diagrams, not instances?
P.S. Why would I create instances?
« Last Edit: February 22, 2013, 12:10:07 am by markl »
Re: Links not instances
« Reply #1 on: February 22, 2013, 12:16:30 am »
Use ctrl-drag and change the default.
Instances are useful where they are useful...
« Last Edit: February 22, 2013, 12:17:23 am by qwerty »
markl
« Reply #2 on: February 22, 2013, 11:06:01 pm »
Thanks for that but this does not seem to work. If I do that for a use case for example. The next use case I drag onto a diagram show the link / instance choice dialog again. The default seems to be individual for a UC not for all objects
« Reply #3 on: February 22, 2013, 11:45:59 pm »
You can turn that off again in the options of the dialog. It has changed in V10 so I can't tell what it looked like exactly but there is a check-box somewhere inside.
I think that this option should be bound to the diagram type. But it is a global option unfortunately.
« Last Edit: February 22, 2013, 11:48:18 pm by qwerty »
markl
« Reply #4 on: May 29, 2013, 06:38:37 pm »
Hello any clues as to where that global option is, since I keep creating unwanted instances? Thanks
« Last Edit: May 29, 2013, 06:39:38 pm by markl »
« Reply #5 on: May 29, 2013, 07:02:58 pm »
Whenever you ctrl-drag an element onto a diagram EA shows a dialog that contains the option.
