Author Topic: Error on Schema Import  (Read 3608 times)
rothnic
« on: August 30, 2013, 11:11:29 pm »
I haven't had issues with this in the past, but I don't see any issue with the source XSD.
The error is:
Error:
Code=0xc00ce504
Source= Line : 12; Char : 208
Error Description = A name was started with an invalid character.
The output of the import window isn't very usable to see if the error was on one of the linked XSD files. But it appears to choke on the main XSD (hard to tell for sure since the window can't be resized to see the full path).
Line 12 of the XSD was a large comment. I deleted the entire comment and the error stays exactly the same. Unfortunately, I cannot post the schema.
Update: After opening the XSD source it appears some of the linked XSDs open in EA with a Parse Error that points to the last element </schema>. So I don't know if that points to any common issue.
« Last Edit: August 30, 2013, 11:21:10 pm by rothnic »
