Author Topic: Is there a bug using PORT ALIASes  (Read 4556 times)
Doug Blake
« on: November 04, 2013, 10:19:11 pm »
I have some components with ports and have been experimenting with different document options, so I decided to apply a unique alias to each port using the properties window.
Now some of my ports labels are displayed with name / alias in the project browser and in my diagrams. If I open the properties dialogue for the port, the alias name appears in a box labelled 'Role' but in the properties window, its an alias. Surely Role isn't the same as Alias??
Also, and more worrying, there are situations where the / alias seems to disappear and come back again later, but I haven't yet worked out what I do to repeat it consistently. More on that later.
DGB Using 12.0.1214 / eaDocX 3.6.2.1 / MSSQL / TFS / Windows 7 / IE11
Re: Is there a bug using PORT ALIASes
« Reply #1 on: November 04, 2013, 10:49:40 pm »
I guess that's correct. A Sparxian commented on this some time ago here on the board.
« Reply #2 on: November 06, 2013, 09:01:30 am »
There's a checkbox at Tools | Options | Diagram | Behavior . It's called 'Use alias field for role'.
Doug Blake
« Reply #3 on: November 06, 2013, 07:36:36 pm »
Thanks for that Simon. Did you know when its on, that the Alias "leaks" into the project browser too with some unusual effects?
e.g with numbering on a PORT does this
1.2.1 Attribute / A123
becomes
Attribute
only to revert later
Will report as a bug
