Author Topic: Printing diagrams at large size  (Read 4617 times)
rickturner646
« on: January 20, 2014, 09:19:52 pm »
Hi folks,
I need to be able to print a (complicated) class diagram at A1 or A0 size [for a training session where I cant use electronic media, if anybody is curious about the reason]. I have the current build of EA but it will only allow me to set drawing properties to a max size of A3. I've tried printing to PDF etc but get multiple pages and it looks horrible.
So, does anybody know how I can accomplish this?
If I could export the drawing to a high-res jpeg file that would be a workaround (I can print the jpeg) but I cant seem to save a diagram into that format either..... so, I am stuck.
Any help gratefully received!
Rick
Re: Printing diagrams at large size
« Reply #1 on: January 20, 2014, 11:32:35 pm »
IIRC (there was a recent similar discussion) this depends on the printer's limits. Try something like FreePDF. That should give you more options.
rickturner646
« Reply #2 on: January 22, 2014, 03:10:52 am »
I'll try that, thanks.
I did wonder if it was linked somehow to what printers (well, printer drivers) were installed on the machine, so I added an A0 plotter but it made no difference - EA still maxes out at A3. Sigh.
Rick
« Reply #3 on: January 22, 2014, 04:36:37 am »
You're right that FreePDF does not seem to offer a larger paper size. But switching the printer gave different paper options. For my Canon A3 printer it even offered custom paper sizes (but then only up to A3). So I guess with an A0 printer attached you can select that size.
Maybe there is some PDF printer that offers A0 too?
P.S. FreePDF emulates an Apple LW 12/660. So if you have some advanced driver you can probably also print A0. It definitely depends on the pinter driver.
« Last Edit: January 22, 2014, 04:39:02 am by qwerty »
AndyJ
  • It's only a model
« Reply #4 on: January 24, 2014, 02:07:17 pm »
You've probably already solved this but...
I print diagrams at totally ludicrous sizes, with an HP plotter.
If you install a printer driver for a plotter (ideally pick one with the largest paper size) you'll be able to add a wealth of new sizes.
Edit:
PS... The current device is a HP DesignJet T790ps 44in PS3, if you install a driver for that printer, you should be good to go.
« Last Edit: January 24, 2014, 02:09:43 pm by novaphile »
