Author Topic: Sequence Diagram Lifelines  (Read 6301 times)
j76nm5
« on: March 20, 2014, 06:40:31 am »
Is there a way to move the sequence diagram lifelines vertically, up and down.  They currently can be moved horizontally.
John
Re: Sequence Diagram Lifelines
« Reply #1 on: March 20, 2014, 07:29:25 am »
Hold the ALT key while moving.
How can you move them horizontally :o
I was thinking of messages  :-[
« Last Edit: March 20, 2014, 08:50:04 pm by qwerty »
j76nm5
« Reply #2 on: March 20, 2014, 08:31:39 am »
When I drag place a lifeline on the sequence diagram, the lifeline is placed near the top of the page.  I would like to pull the lifeline down a little so that I can put text at the top of the diagram without writing over the top of the lifelines.
holding down the alt button while I select and then try to pull down the lifeline does not seem to work. I still can only move the lifeline to the left of right...not up and down.  I know how to shorten or lengthen a lifeline...I want to move the whole object down on the sequence diagram.
thanks in advance
John
« Reply #3 on: March 20, 2014, 09:10:24 am »
If you right-click in empty space on the diagram, there is a command "Set Top Margin" that might help you. There is no way to move individual lifelines down.
« Reply #4 on: March 20, 2014, 09:45:05 am »
Except sending it a "new" message.
