Author Topic: Generating linked report  (Read 3305 times)
Mako
« on: September 14, 2006, 08:12:55 am »
Hi all,
I am trying to generate a report of my release plan.
1. I have created a number of packages and several requirements in each package.
2. I have created a diagram that contains links to requirements in the different packages.
How do I get the RTF generator to display all requirement elements that are present on the diagram?
Hope for help.
/Per
Re: Generating linked report
« Reply #1 on: September 14, 2006, 04:07:04 pm »
Hi Per,
If the diagram and the requirements themselves are owned by different packages you may have to fiddle with the rtf generation options a bit.
Also, as a sanity check try generating with the Use Template drop down set to both (basic template) and (requirements template). See if the requirements show up, and look at the differences. If they don't, make sure you are reporting on a package 'above' the requirements elements in the hierarchy, and that you have not excluded packages by phase or elements by status.
HTH, David
