Author Topic: Copy Diagram Shallow  (Read 4366 times)
Barb
« on: July 01, 2014, 03:01:40 am »
I am using EA version 11.0.1107 on Windows 7 with a SQL Server repository.
When I copy an object diagram "shallow", it still duplicates all of the objects - even when I am in the same package.
I really need a copy of the diagram reusing the same objects.
I believe this is a bug.
Re: Copy Diagram Shallow
« Reply #1 on: July 01, 2014, 09:11:09 am »
The shallow copy still duplicates some types by design. This includes objects, text, notes. ie. Things that aren't generally for re-use.
See http://www.sparxsystems.com/enterprise_architect_user_guide/10/modeling_basics/duplicateadiagram.html
Links back to the original diagram elements, unless those elements are Text, Note, Hyperlink, Lifeline or Object elements that are specific to the diagram and that are copied  (shallow mode)
Barb
« Reply #2 on: July 01, 2014, 10:39:00 pm »
This answer does not make sense to me.  The object elements have their own hierarchy in the project tree; they are not children of a diagram.  The same concept as a class element ... the diagram really contains a pointer to the object, it does not own the object like it does a note or a boundary.
Where can I find a list of model elements that will not copy?
thanks
« Reply #3 on: July 01, 2014, 10:52:08 pm »
When I use ctrl-c/v it copies all elements as links (at least in a class diagram).
