Author Topic: Read EAP Files in Package  (Read 8615 times)
arphex
« on: June 26, 2014, 06:31:41 pm »
With Code Engineering --- >Read Source Directory i can get a Folder structure in EA.
Is it possible to read EAP-Files with "reverse Engineering"?
Because its sparx-own file Format it should not be very complicated?
best regards
Uffe
Re: Read EAP Files in Package
« Reply #1 on: June 26, 2014, 06:44:47 pm »
The content of an .EAP file is actually a database, so you can't reverse-engineer it like you would source code.
You can reverse-engineer databases (including EA's own) into EA with the Import DB Schema function, but you'll only get the structure this way -- not the contents.
« Reply #2 on: June 26, 2014, 07:44:56 pm »
What would you expect to get from the reverse engineering?
arphex
« Reply #3 on: June 26, 2014, 08:17:57 pm »
I have some DBMS repositories, but in some cases we have a Folder structure with EAP Files.
I wanted to read the Folder structure and set on "Filetype" .eap.
So EA would recognize the eap and Show it for each Folder.
Uffe
« Reply #4 on: June 26, 2014, 08:45:19 pm »
You can create a hyperlink of type File - Open (from the Common toolbox in any diagram) and specify the EAP file there. Double-clicking the hyperlink will then open the project.
« Reply #5 on: June 27, 2014, 05:02:18 am »
Alternatively you can create Artifact elements and use the File tab to point to your real file.
arphex
« Reply #6 on: June 27, 2014, 03:12:50 pm »
good morning
Thank you for your replies, i will check the possibilities.
best regards
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
« Reply #7 on: July 16, 2014, 02:38:17 am »
You can create a script that read the folder structure and create the suitable packages within de EA model.
