Author Topic: Attribute Stereotypes Do Not Reload in UI  (Read 4595 times)
Gareth
« on: December 21, 2013, 05:08:05 am »
Some of our users are experiencing the problem that an Attribute's Stereotype is not loading into the Stereotype field within the edit attribute screen. This means that for any Attribute, if they edit it, the Stereotype is lost. (It's stored in the database since it's visible in the grid and elsewhere -- just not loaded when they edit.)
Of note:
  • It occurs for only some users. For those users it is all of the time -- it is not intermittent.
  • It occurs when using our Oracle EA repository. It doesn't occur when they use a file repository.
  • It occurs from both a local instance of EA and a Citrix instance --hence it seems to be tied to the user's login, rather than an EA install.
  • It seems to occur (may be coincidence) with just those users that have been using the system for approximately less than a year -- older users don't have the problem.
  • We have security active and use Windows Authentication. Of users with identical rights, some have the problem, some don't
Marc Vanstraelen
Re: Attribute Stereotypes Do Not Reload in UI
« Reply #1 on: December 17, 2014, 03:00:17 am »
One of our users reported the same problem (EA version 10). Any indications?
« Reply #2 on: December 18, 2014, 09:21:02 am »
Is it just the «XSDelement» stereotype?
Note that the attribute properties dialog has been completely re-worked for EA 12 - there is a pre-release version (including Trial and Lite editions) if you want to see if it fixes your problem.
« Last Edit: December 18, 2014, 09:23:07 am by KP »
« Reply #3 on: December 18, 2014, 10:04:37 am »
Tried to reproduce with 10 and 11 but it worked without issue. Also tried the XSDElement.
