Author Topic: BPMN 2.0 Task type Service  (Read 8144 times)
akopp
« on: January 20, 2015, 08:11:40 pm »
In rel 11 new activities added can not be changed to task type service as the task type drop down list doesn´t this type.
Has somebody else the same experience.
Since we need to show this activity type in our diagrams, who knows a workaround.
Re: BPMN 2.0 Task type Service
« Reply #1 on: January 21, 2015, 08:27:30 am »
If you were previously able to do it, you can still do it by opening the tagged values docked window.
PS. I don't know if what you're wanting is an actual BPMN type. If it is, then it sounds like it may have been omitted and needs to be corrected.
MMA
« Reply #2 on: January 21, 2015, 10:53:44 am »
Hi akopp,
You could find "Service" in 3 ways.
1. Quick menu when dropping Activity on diagram, select "Service";
2. Property Window | BPMN2.0 page | Type combobox | select "serviceTask";
3. View | Tag Values | taskType | select "Service"
Hope that helps ;)
Stoppy
« Reply #3 on: January 21, 2015, 11:44:30 am »
Hi akopp,
MMA has covered of the functional steps.
I am on EA V 11.0.1105 and not experiencing your issue, could you supply more context to your problem.
Stoppy  :D
« Last Edit: January 21, 2015, 11:45:15 am by Stoppy »
Skills: Business Process | Business Analysts | Product Configuration Manager | Business Intelligence
akopp
« Reply #4 on: January 21, 2015, 09:00:38 pm »
MMA and the others,
Thanks. I am now able to change activities to a service tzpe.
Regards
Andre
