Author Topic: Legend is not saved  (Read 7352 times)
Wilbert
Legend is not saved
« on: January 27, 2015, 07:11:42 pm »
Hi all,
When I include a legend within a diagram, the contents of the legend are not saved. If I save, exit and reopen my Project, the legend is still there but empty. Is this a known issue (could not find any references to it), or am I doing something wrong?
Gr., Wilbert
Re: Legend is not saved
« Reply #1 on: January 27, 2015, 08:42:33 pm »
Haven't heard that, but you should state your EA version.
Wilbert
« Reply #2 on: January 28, 2015, 09:14:18 pm »
Sorry, you're right.
I use the Corporate Edition, version 11.1.1111 (build 1111)
Gr., Wilbert
« Reply #3 on: January 28, 2015, 09:21:22 pm »
Just tried that and I had no issue. Does it happen with all repositories? Have you tried with a fresh empty EAP?
Wilbert
« Reply #4 on: January 28, 2015, 11:23:07 pm »
Hmm, I tried it with a fresh project and now it works OK. But the project that I had the issue with, still does not work. Write -> Close EA -> Open results in empty Legends...
Gr., Wilbert
« Reply #5 on: January 29, 2015, 01:49:42 am »
Try a project integrity check. That helps sometimes. If not: contact Sparx support directly per mail.
Takeshi K
    • Sparx Systems Japan
« Reply #6 on: January 29, 2015, 11:46:08 am »
Just for your information, I know the same behavior when I use JET 3.5-based EAP file. If it were the same issue, copying your project file to JET 4.0-based EAP (or maybe FEAP) could solve the issue.
t-kouno
