Author Topic: Document Generation Freezes - lists in Notes  (Read 3718 times)
jw11
« on: February 11, 2015, 10:48:14 am »
11.1.1112 Build 1112
I've noticed that when my Requirement Notes have lists, bullet-ed or numbered, document generation fails (when I've included the Requirement Notes).  Doesn't matter if it is PDF or Word. -as soon as the Notes are included, the process freezes and I must close EA.
If I change the Note and remove the list, or un-list the text, document generation proceeds normally.
Any workarounds?  Any one else experiencing this?
AndyJ
  • It's only a model
Re: Document Generation Freezes - lists in Notes
« Reply #1 on: February 11, 2015, 03:10:52 pm »
I've seen a similar problem, where bulleted lists would only contain the first value in .pdf document generation.
I'm fairly sure that one was fixed though.
danbosscher
« Reply #2 on: February 12, 2015, 06:13:11 am »
I think I've been experiencing the same problem or a similar one lately. If I import a template from a reference file and don't open it before generating a report with it, document generation freezes and I have to restart EA. As soon as I open the template everything works fine again.
I did not have a Requirement Notes section but I did have a Method Notes section also with a list.
I'm using 11.0.1107 Build 1107 on Windows 7 64-bit
jw11
« Reply #3 on: February 13, 2015, 03:14:52 am »
After more investigation, my colleagues are not experiencing the same issue.  With the same version of EA and the same EAP file they can generate documents without issue.  Lists and all.
This looks like it is a problem with my installation or my desktop.
