Author Topic: Language in element names  (Read 6148 times)
Rade
« on: March 10, 2015, 12:29:05 am »
I work on a project that has to be in Serbian language, so I need element names and notes in Serbian Latin.
But all characters specific to Serbian language get lost  :(
Is there an option that I have missed, because this is starting to be a really big problem.
Re: Language in element names
« Reply #1 on: March 10, 2015, 01:03:11 am »
You probably need to change to Jet 4.0 in the settings
Tools|Options|General|Use Jet 4.0 - requires restart
« Reply #2 on: March 10, 2015, 04:50:01 am »
There's also a template Jet4 base EA project somewhere on Sparx resourvce site.
« Reply #3 on: March 10, 2015, 06:49:46 am »
Its really hard to find because while it is on page http://www.sparxsystems.com/resources/
under the heading "Team Modelling and DBMS setup"
the resources (links) are rolled up and not visible.
The heading itself has no associated page and explanation of the links provided.
This is just not good UI design (hello).
Here is the direct link, I cannot find a page where a description of this is provided.
http://www.sparxsystems.com/bin/EABase_JET4.zip
« Reply #4 on: March 10, 2015, 10:08:57 am »
Great! Hopefully I recall that post the next time it's needed.
Rade
« Reply #5 on: March 10, 2015, 09:47:05 pm »
This works fine in a local .eap file. But I still have the same problem when I transfer the project to DBMS.
Any ideas as to what the problem could be?
I use Oracle and connect through Microsoft OLE DB Provider for ODBC Drivers
« Reply #6 on: March 11, 2015, 11:42:39 pm »
In that case you did something wrong with either the collation in your database of with the driver.
I know EA is rather picky about the database driver for Oracle.
« Reply #7 on: March 12, 2015, 08:28:27 am »
The documentation states that the Microsoft OLE DB Provider for Oracle isn't supported.
