Author Topic: Issues with Notes: &  (Read 6745 times)
« on: January 21, 2011, 12:31:20 pm »
Recently (864  at least) we have noted that in some, but not all cases, the use of an ampersand (&) in a note results in the text & being output in the generated RTF document?
We also noticed that if two spaces precede the & this doesn't happen.
Bug?
Re: Issues with Notes: trailing spaces after a lis
« Reply #1 on: January 21, 2011, 12:36:09 pm »
In a note field where the field ends with text it is possible to not have a trailing newline character.
This is great because in a RTF document template the note field can be placed in a table cell without a pesky blank line at the bottom of the cell, or too much white space after a paragraph in normal layout.
But (at least in 864) this does not seem the case if the note finishes with a list.
No matter how often I delete the trailing newline characters they come back.
Bug?
(PS a new note field has no content (not even a new line), but once something ha been entered it is impossible to delete the newline character once everything else is deleted).
Re: Issues with Notes: &
« Reply #2 on: January 21, 2011, 06:27:17 pm »
Skiwi,
I suspect we can consider both issues a bug.
Have you reported them?
alesliehughes
« Reply #3 on: January 25, 2011, 08:43:15 am »
This has been fixed and will be found in the next Release of EA. (date unknown)
Mitch
« Reply #4 on: January 29, 2011, 05:02:22 am »
Speaking of issues with notes and reporting...
Whenever I create a note with a bulleted list (I'm using a Feature element right now) the lists end up numbered when I print them out in a report. If I have multiple elements with bulleted lists the numbers are even consecutive across elements, which is really wrong regardless.
I'm currently using build 863 (while I'm waiting for corp to renew support) but I don't see a release note addressing this specifically; I don't suppose we could get this one fixed at the same time? :)
« Reply #5 on: January 31, 2011, 06:28:00 am »
Thanks very much
alesliehughes
« Reply #6 on: January 31, 2011, 08:19:06 am »
Please send an email to support with this issue.
Alistair
Mitch
« Reply #7 on: February 01, 2011, 01:16:06 am »
Alistair
Done.
« Reply #8 on: April 22, 2015, 09:05:27 am »
Trailing spaces on lists fixed (I hope) in EA 12.1212
