Author Topic: Auto-capitalization?  (Read 10741 times)
jklap
« on: April 24, 2015, 03:29:05 am »
Haven't used EA 12 much-- but have been using EA since version 8-- and for the life of me I can't find how to disable auto-capitalization for table columns-- which seems to be a new "feature" in 12?
Re: Auto-capitalization?
« Reply #1 on: April 24, 2015, 05:44:45 am »
Don't tell us you did not want it. You just did not know how to live without it till now ;D
Modesto Vega
« Reply #2 on: April 24, 2015, 05:53:14 pm »
Joke aside. I personally find this particularly annoying. I have asked the very same question on a separate thread and got no answer.
Furthermore, I think this a new feature (intended or unintended) of EA12; I have done data modelling with EA before and do not recall the column names being auto-capitalize.
« Reply #3 on: April 24, 2015, 07:27:06 pm »
Please remember that this is a user forum with the intent to share experiences between users.
Although this forum is moderated by Sparx employees, and they regularly participate in discussions, this is no official support channel.
Nobody here is in any way obligated to respond to any question.
If you have an support issue, bug, or change request you have to use the "official" channels.
 - bug report
- feature request
Modesto Vega
« Reply #4 on: April 24, 2015, 07:55:33 pm »
 - bug report
- feature request
Fully aware of this, but would you be too surprise if the is a setting hidden deep into EA to control this? I wouldn't be the first time.
I haven't found that setting yet and still hope I will bump onto it accidentally or somebody points that setting out to the community.
Modesto Vega
« Reply #5 on: April 24, 2015, 08:05:42 pm »
Bug report submitted, thanks for the reminder Geert.
jklap
« Reply #6 on: April 25, 2015, 12:28:42 am »
Thanks for raising the bug report!
« Reply #7 on: April 25, 2015, 12:40:15 am »
If you also send a report the priority will raise....
Modesto Vega
« Reply #8 on: April 25, 2015, 01:06:17 am »
jklap - could you please also submit a bug report. I can send you what I wrote on a PM.
jklap
« Reply #9 on: April 29, 2015, 01:12:16 am »
Will do-- I'll flavor your bug report as needed :)
Modesto Vega
« Reply #10 on: April 29, 2015, 01:20:35 am »
I found out today that the Columns and Constraints dialog is the one creating the problem. The foreign key creation dialog does not change the case.  :)
You can create a foreign key constraint named FK_Abc_Def by creating an association between both tables. But as soon as you try editing the name in the Columns and Constraints dialog to for example FK_Abc_Def1 EA12 upper cases everything and you end up with FK_ABC_DEF1.
« Last Edit: April 29, 2015, 01:21:53 am by modesto.vega »
