Author Topic: Pasting rich text into notes  (Read 10565 times)
« on: March 20, 2013, 03:04:22 am »
I'm on V10. When pasting rich text into class notes I see two effects:
- The original size appears when pasting, but once re-opened the font has the default size
- Leading blanks seem to be stripped off
(FWIW: The paste buffer is filled from my Mac and travels through Parallels into the windoze environment, but that works fine for other applications.)
Anyone seeing the same result?
[edit] The leading blank stripping seems to be an issue with EA/Parallesl paste buffer. When I paste into Wordpad first the leading blanks are preserved. Only when pasting directly into EA they get stripped. However, the size issue is still there.
« Last Edit: March 20, 2013, 03:09:48 am by qwerty »
Re: Pasting rich text into notes
« Reply #1 on: March 20, 2013, 09:24:16 am »
For as long as we've had rich edit controls you could paste text with formatting that EA didn't support and see this behavior. It's a bug, but I think a relatively minor one.
« Reply #2 on: March 20, 2013, 10:39:59 am »
I once worked for Siemens and whenever their QA found things like that you had to correct it. Probably QA in Germany and Australia have a different attitude. But I wished your QA would be a bit more Germanized...
« Reply #3 on: April 08, 2013, 08:07:28 am »
This so called "bug" - more likely just neglectfulness on the part of a requirement specification, has been around for at least 4 major versions of EA.
See the image below for what happens (cute eh) when you paste from Word tables (and this has been reported by me as a bug)
See also
* notes naughtiness and nuisances - table paste
* Notes paste does not work as expected
* Embed graphics into notes field and Embedding images in Notes
* Richer note fields (on elements)
« Last Edit: April 08, 2013, 08:07:54 am by skiwi »
Edward IV
« Reply #4 on: April 09, 2013, 07:42:22 am »
Notes in EA are pretty poor.  They don't even support sub-lists, such as:
1. Item 1
2. Item 2
    a. Item 2a
    b. Item 2b
3. Item 3
If you paste it in from a document, it displays correctly, but loses it all when you click out and refresh.
This should be considered a bug - and not a "minor" one because using the Generate Documentation feature really suffers here.
« Reply #5 on: April 09, 2013, 10:31:44 am »
Unfortunately this is a Catch 22. EA has it's internal storage format for notes and they don't dare to move away from it.
Edward IV
« Reply #6 on: April 09, 2013, 12:47:54 pm »
That doesn't make much sense - I don't see the Catch 22 here and I don't see why they don't either add more formatting features or just a regular RTF editor for the notes.  The other thing is that even if you link an RTF file to a component to get around the formatting limitations, the RTF doesn't get exported when you generate a document (at least no by the built-in tempates).
« Reply #7 on: April 09, 2013, 06:08:47 pm »
If someone sticks to a proprietary format for more than 10 years while there's HTML outside this definitely looks like a Catch 22 -  at least for Sparx, the provider of the format. You'll get caught too if you start thinking, they're going to change it :-X
« Reply #8 on: August 21, 2014, 12:03:55 pm »
bug reports or not, this is still not fixed in EA 11
« Reply #9 on: May 15, 2015, 01:15:58 pm »
not in EA 12
mgm
« Reply #10 on: November 17, 2018, 12:08:11 am »
not in EA 14
« Reply #11 on: November 28, 2018, 06:21:48 am »
Woah! Lotus Notes is still used. I'm baffled.
Glassboy
« Reply #12 on: November 28, 2018, 08:21:40 am »
It's like the herpes virus of IT systems :-)
Actually it's not that bad.  We have some case management systems here in NZ running on Notes that have extremely low cost of ownership.
« Reply #13 on: November 28, 2018, 07:04:55 pm »
What a coincidence. I just got my yearly herpes outbreak just this week.
