Author Topic: Error 'Invalid Data Source, check configuration'  (Read 7111 times)
Ian McIntosh
« on: May 19, 2015, 07:45:22 pm »
I am trying to setup MSSQL with EA v11
I get the error 'Invalid Data Source, check configuration'
I've created a database, run the install script without error, setup the ODBC data source & tested it - all OK.
When I try to open a project and connect to the server, I select my newly created connection, enter the user name & password. I press test connection & it passes that.
I then press ok, once again enter user name & password, then get the error message above.
Re: Error 'Invalid Data Source, check configuratio
« Reply #1 on: May 19, 2015, 08:34:46 pm »
You need to fill that DB before you can use it. Open an EAP and user Project/Data Management/Transfer.
Ian McIntosh
« Reply #2 on: May 19, 2015, 09:38:57 pm »
thanks for the reply.
Any idea which is the best SQL driver to use with EA?
The instruction video suggested EA should identify the database is empty & prompt a transfer.
However, going via the transfer function directly did at least give me a bit more info on the problem. It complained of an unsupported driver. I switched to using SQLOLEDB and now its doing something - but its progressing very slowly. The dialog box has stopped responding & looks like its hung, but I can see the number of records in the database increasing.
(as a test I'm just using the example eap, which I needed to run a clean on before I could do the transfer)
« Reply #3 on: May 19, 2015, 09:54:24 pm »
EA supports native MSSQL but it partially depends on which version you use. ODBC should work in almost all cases. You can change the driver later at any time.
