Author Topic: Bugs in Show differences (Package Baselines)  (Read 4407 times)
larsw
« on: June 29, 2015, 07:19:42 pm »
 I'm experiencing a whole range of strange behaviors when I try to use the "Show differences" feature in the Package Baselines... dialog to figure out "leakage" from one top level model to another.
Here is what I'm trying to do:
Given a project with two top level models, I take a package baseline on one of them (the one I want to keep).
After the baselining is done, I remove the other model with all its contents, and open up the Package Baselines... dialog again on the remaining model.
Further, I use Show differences... and as far as I understand how it is supposed to work, the model diagrams and connectors that should show up in the diff report should be those affected by the other top level package I removed.
Observations:
 * If I don't configure "Suppress date created" it can actually report that some elements has changed values for the creation timestamp (!)
* There is a lot of false positives, especially related to a buggy comparison on the text in the Notes attribute on elements. This might be caused by the fact that the Notes attribute is Rich Text and not plain text.
* It can report that it changed a lot of diagrams (visually) and just nudged some connectors a couple of pixels in one direction or the other - nothing is remotely related to the other top level package that I removed.
* It reports that on some Ports (that is inherited from other components) there exists text in the Notes attribute on the current post-baseline elements, but not in the pre-baseline, which is very strange, since I haven't touched anything between the baselining and diff (apart from deleting the other top level package).
Right now, the whole feature is pretty much useless :-/
I'm running EA 11.1.1111
Re: Bugs in Show differences (Package Baselines)
« Reply #1 on: June 29, 2015, 07:26:59 pm »
I would recommend doing the same test on v12. If you still have the same issues (you probably will) then report it to Sparx.
RoyC
  • Read The Help!
« Reply #2 on: June 30, 2015, 09:33:40 am »
What happens if you have the two models, you take a baseline of one of them, and then do a compare between the baseline and its source model WITHOUT having deleted the other model?
Probably the best thing to do is send a copy of your project to Sparx Support.
Best Regards, Roy
