Author Topic: Linked document and element update time  (Read 6055 times)
Uffe
« on: August 28, 2015, 05:58:48 pm »
Hi all,
If I've got a «Document» and I edit its contents, the element update time is unchanged. This would only be a minor annoyance if not for the fact that the element is not marked as modified in a baseline comparison.
Is this by design or a bug? I'm on EA 11, btw.
/Uffe
Re: Linked document and element update time
« Reply #1 on: August 28, 2015, 06:36:00 pm »
Hi Uffe,
If you mean a Document created from the Artifacts toolbox page, then under 1215 it does update the modified time - BUT I had to leave the element and come back to it (on the diagram or the browser).
EAUI maybe?
« Last Edit: August 28, 2015, 06:36:20 pm by PaoloFCantoni »
Uffe
« Reply #2 on: August 28, 2015, 06:41:56 pm »
Hey Paolo,
It seems to depend on the DB engine. The date is updated correctly in a SQL Server database, but not in a JET one.
Could you confirm that it works on JET in 1215?
/Uffe
« Reply #3 on: August 28, 2015, 08:31:13 pm »
I just tested it. The properties window updates the (display of the) modification time only after de-/reselecting the artifact. But it updates.
« Last Edit: August 28, 2015, 08:31:26 pm by qwerty »
Uffe
« Reply #4 on: August 28, 2015, 08:52:04 pm »
OK, so that's just an 11 thing that's been fixed in 12.
Thanks, guys.
/U
« Reply #5 on: August 28, 2015, 09:46:23 pm »
I retried with 1107 and it worked correctly too.
Uffe
« Reply #6 on: August 28, 2015, 10:28:35 pm »
Weird. I'm on 1112 and it doesn't work.
... You are testing on a JET database, right?
« Reply #7 on: August 29, 2015, 12:42:46 am »
Yes, standard EAP.
« Reply #8 on: August 29, 2015, 10:26:19 am »
Hey Paolo,
/Uffe
Hi Uffe,
it was a Jet4 DB.  We (effectively) ONLY use Jet4 (and SQL Server).
