Author Topic: V12 Editing features in diagram broken  (Read 5769 times)
« on: September 02, 2015, 09:41:23 am »
Is it just me, but when I try to edit attributes directly in the diagram, the attribute is "trashed".  For example suppose I have:
AttributeName datatype
And I try and change the name to SomeAttribute Datatype,
I end up with Some (and no Datatype).  It's REALLY annoying if I forget to View Properties on the attribute and edit it in the dialog - where things work OK.
Anyone else seeing this or just me?  I'd like confirmation before I report it.
TIA,
« Last Edit: September 02, 2015, 09:41:58 am by PaoloFCantoni »
Re: V12 Editing features in diagram broken
« Reply #1 on: September 02, 2015, 09:47:59 am »
Inline editing doesn't work if you have spaces in the attribute name. Is that the problem?
« Reply #2 on: September 02, 2015, 03:39:29 pm »
Woaa. I almost never use inline editing. But this got top of EAUI at once.
« Reply #3 on: September 02, 2015, 05:35:49 pm »
Yes  It is.  I suspected same, but didn't want to bias the responses.
So is it a bug?  I'd say so.  Whether there are spaces in the name or not, the syntax is pretty explicit.
« Last Edit: September 02, 2015, 05:43:48 pm by PaoloFCantoni »
« Reply #4 on: September 02, 2015, 05:38:03 pm »
Yes, It's always been a bit "Iffy" so I avoid it, but sometimes, you can't stop yourself...
« Reply #5 on: September 03, 2015, 08:55:39 am »
It's not expected to handle spaces in the name. When we wrote the parser that powers that feature we had to make some restrictions.
However, what may be a bug is that it accepted a partial parse as valid.
« Reply #6 on: September 03, 2015, 10:34:15 am »
It's a bug ...
Since (as far as I can tell) ALL the other input/edit mechanisms ALLOW spaces in the attribute name, to have this mechanism NOT handle them is INVALID.
The inconsistent (and therefore wrong) decision was made in design/coding.
Reported,
« Last Edit: September 03, 2015, 10:42:00 am by PaoloFCantoni »
« Reply #7 on: September 03, 2015, 11:54:49 am »
This method of input is fundamentally different from dialog based input where one entry box represents the exact contents of exactly one field. Extending your argument, I should also be able to define attribute names containing punctuation including colon.
« Last Edit: September 03, 2015, 03:04:51 pm by simonm »
« Reply #8 on: September 03, 2015, 05:59:34 pm »
No, that's not what I'm saying.  It's a consistency thing.
I strongly suspect that if colons were allowed in attribute names, one could come up with an algorithm that would sort it out for you!  I mean Microsoft managed it - allowing embedded periods (full stops) in file names and still using it to separate the file base name from the file extension.
It just takes more "Denkstoff".
