Author Topic: Add Element... dialog crashes EA  (Read 19314 times)
« on: July 23, 2015, 06:02:55 pm »
If you use the Add Element... context menu item on a packge in the browser, the New Element dialog is opened.
if you use the [Save] button instead of [Save & Exit] a short time after the element is placed on the diagram, EA crashes.  Is it just me or is it a more common problem?
If it's common, I'll report it.
TIA,
Re: Add Element... dialog crashes EA
« Reply #1 on: July 23, 2015, 08:07:00 pm »
About which "Save & Exit" are you talking? I can't follow your steps.
« Reply #2 on: July 23, 2015, 10:02:15 pm »
Select a package in the browser,
Right click to show the context menu,
Select Add Element... (just above Package Control>)
the New Element dialog should appear with 4 buttons:
[Save] [Save and Exit] [Cancel] [Help]
Make sure [X] Add Element to Current diagram is marked
If you [Save} (rather than [Save and Exit]) if you move the mouse, EA will crash.
« Reply #3 on: July 24, 2015, 12:36:22 am »
I only see three buttons: Save, Cancel and Help. Using 1208.
« Reply #4 on: July 24, 2015, 05:39:52 am »
There's 4 on 1215.  If the change is this recent, that might explain the "unfinished code".  ;)
« Reply #5 on: July 27, 2015, 05:49:52 pm »
[size=20][BUMP][/size]
Can anyone confirm/deny this behaviour, please?
« Reply #6 on: July 27, 2015, 08:07:49 pm »
For me it does not crash. Probably you should check the usual suspects aka. add-ins.
Stefan Bolleininger
« Reply #7 on: July 27, 2015, 08:13:02 pm »
Hi Paolo,
I can confirm the Button is existing :-) and your bug as well :-)
"Save" creates the element, added it to the diagram and the project browser and the dialog is still open.
After pushing the "Cancel"-Button, EA. breakes.
Regards
Stefan
« Reply #8 on: July 27, 2015, 08:53:25 pm »
So you just need to get out what you both have in common that I don't have.
« Reply #9 on: July 28, 2015, 09:52:02 am »
I found what appears to be a related bug report.
It appears to be a regression in Windows 8 due to accessibility settings. (ie. It impacts a subset of Windows 8 setups)
We're looking into a fix and possible workarounds.
« Reply #10 on: July 28, 2015, 09:58:28 am »
Hi Paolo,
Regards
Stefan
Thanks Stefan,
I found, like you, that the [Cancel] button crashes, but all I really needed to do was wait and move the mouse around a bit.
« Reply #11 on: July 28, 2015, 10:00:26 am »
Thanks Simon,
My setup is both Windows 7 and windows 8.1.  I think (from memory) that  it happens on both.  My main machine is currently a Windows 7 machine (on which the crash is present) so I'd need to specifically check on Windows 8.1.
« Last Edit: July 28, 2015, 10:00:50 am by PaoloFCantoni »
« Reply #12 on: July 28, 2015, 06:10:30 pm »
Simon,
Do I need to formally report a bug or is this already "in train".
« Reply #13 on: July 29, 2015, 09:09:44 am »
Paolo,
That depends on how likely you think that it's the same issue. As I said, we haven't reproduced it on Windows 7.
My personal opinion is that a fix for the issue we have found is likely to apply to your situation too.
« Reply #14 on: July 29, 2015, 10:00:05 am »
Paolo,
My view is there's nothing to lose by reporting.  If it gets fixed by the other bug, then good.  I'll pop one in shortly.
[edit]Reported[/edit]
« Last Edit: July 29, 2015, 10:07:55 am by PaoloFCantoni »
