Author Topic: replacing a Subactivity's diagram?  (Read 3923 times)
Arjen
« on: November 10, 2006, 04:05:59 pm »
I removed the diagram of a Subactivity.
Now, I can add a new diagram to it. But it does not automatically open when I click on the subactivity's icon in the activity diagram that contains it. How can I connect this new diagram to the icon?
Thanks in advance,
Arjen
« Last Edit: November 11, 2006, 01:16:29 am by Arjen »
Jan ´Bary´ Glas
  • Bary
Re: replacing a Subactivity's diagram?
« Reply #1 on: November 12, 2006, 10:47:03 pm »
I use such  a workaround:
Make your activity non-composite and then composite again. The link establishes well.
Jan 'Bary' Glas
Arjen
« Reply #2 on: November 13, 2006, 01:28:16 am »
Hi Jan,
Thanks for your reaction.
Maybe you can elaborate a bit? What I found was "Advanced Settings/Set as composite element". Is that what you refer to?
When I tried that, this turned the subactivity into an activity. There seems, however, no way to undo that action? How can I turn the activity back into a subactivity?
Arjen
Jan ´Bary´ Glas
  • Bary
« Reply #3 on: November 13, 2006, 03:18:33 am »
Its easy - check the Advanced Settings/Set as composite element checkbox again. The former (unchecking) brakes the connection; tha later (checking) establishes new connection to subactivity.
Jan 'Bary' Glas
