Author Topic: Formatting in sequence diagrams  (Read 3989 times)
Levent Mollamustafaoglu
« on: March 19, 2002, 06:11:32 am »
When we select "Diagram Properties" and click "Show details on diagram" in a sequence diagram, the automatically generated text can not be re-positioned and tends to obscure the diagram elements in some cases. The text box is not even selectable, so the placement can not be configured.
gsparks
  • I love YaBB 1 Gold!
Re: Formatting in sequence diagrams
« Reply #1 on: March 19, 2002, 09:14:53 pm »
There is an alternative method to using that feature.
In the element toolbar - the one that has Boundary, Note, Text, Notelink, Hyperlink etc., there is also a button for Diagram Notes ... it is the blue 'note' button. Click on this to add a Text element that is internally linked to the diagram properties.
This is a moveable element that can also have the color changed etc.
Hope this helps,
Geoff Sparks
« Reply #2 on: March 20, 2002, 06:28:32 am »
Much better. Could it maybe display the package name as well?  ;)  If you have too many analysis and design elements, some of the diagrams may end up having the same or similar names
