Author Topic: Display an OR relationship between 2 associations  (Read 10771 times)
follop
  • I love YaBB 1 Gold!
« on: March 06, 2002, 08:51:59 pm »
I have been evaluating EA for the past three days and am very impressed. However, I cannot find how to display an "Or" relationship between two associations. Thanks in advance!
sparks
Re: Display an OR relationship between 2 associati
« Reply #1 on: March 08, 2002, 04:46:36 am »
Unfortunately EA does not support this notation at the moment and so far it has not been a very popular request (as you are the first).   However since it is part of the UML specification we will be including it into a future version of EA.  Exactly when this notation will be include is still undecided, at this stage.
Paul Mathers
Philip_Avery
« Reply #2 on: March 13, 2002, 07:42:38 am »
Make that two requests - I needed to OR today (don't we all?) and have found I can't!
asantos
  • I love my work !!
« Reply #3 on: March 13, 2002, 12:26:49 pm »
in fact i have already posted a similar question
General / General Board / 3.42.5.1 Xor-association  on: 02/09/02 at 20:44:06
Why represent a Xor-association describe in OMG-UML v1.4 Binary,  Association page 3-69
Anderson
manfred
  • I love UML
« Reply #4 on: March 31, 2002, 04:40:44 pm »
Ah, here comes one more request!
(for an {xor} this time ... :)  )
Thanks in advance,
Manfred
rvrivera
« Reply #5 on: April 01, 2002, 01:33:39 pm »
Another request of functionality...
Please and display relationships between associations
gsparks
« Reply #6 on: April 01, 2002, 08:20:04 pm »
Hi all,
I have implemented the following in the next update of EA, which should do the trick. This update will be out in a day or two - look for build 479 or higher.
- On a link in a diagram there is now an 'Attach Note or Constraint' context menu item - click on it to attach a constraint
- In the Set Linked Relations dialog that pops up - tick all the relationships in the current diagram that will be part of the note or constraint set
- Mark whether this is a constraint or note
- Press OK - note is created with dotted lines to each memberof the link set
- add expression for Constraint (EA will add { and } characters) or free text for note
Once you have created a note or constraint, you can change the members of the set using the context menu of the Note itself ... there is now a Set Attached Links option if the note has been created as a linked Note or Constraint
This example illustrates:
You may link 1, 2 or more relations with this method.
Hope this helps,
Geoff Sparks
