Author Topic: EA use in multiple developer environment  (Read 2792 times)
croutledge
« on: November 25, 2003, 11:42:38 pm »
The company i work for has just had seom training on UML and EA and are really impressed.  We are about to start using EA as part of a major internal project and i was hoping someone could point towards some documents or describe (in a bit of detail) how we use EA in a multiple developer environment.  I know you can use a DB to store a project, then there is the use of something like CVS and finally the security as well.
We have a team that is on 3 sites and are looking to have all three sites working on the document in EA.
Any help would be much appreciated.
Kind Regards
Carl
Sean Kearon
Re: EA use in multiple developer environment
« Reply #1 on: November 28, 2003, 01:31:58 am »
Hi Carl
The EA Corporate version allows you to lock packages in a model file so that more than one developer can work on the same model.  You can also import/export packages to XMI (the XML model format).  This lets you import the package(s) into a model file, change them, then export them back out and check them into CVS/Source Safe/etc.  We find this the best way to work.
I remember there have been some discussions about this topic on here....there are a couple of links below that might help, but I'm sure there are more.
Sean
http://www.sparxsystems.com.au/cgi-bin/yabb/YaBB.cgi?board=general;action=display;num=1067878205
http://www.sparxsystems.com.au/cgi-bin/yabb/YaBB.cgi?board=general;action=display;num=1057846001
