Author Topic: Importing data from MS Excel  (Read 7682 times)
sandi
« on: March 22, 2004, 04:54:06 am »
Hi all,
does anyone know how to import data from Excel to EA?
For example, I would like to create requirements (for each row in Excel) and put in the required data from Excel columns.
For example, column A in the Excel contains the short description value in EA, column B in Excel contains tag of the requirement in EA, column C contains Details in EA,...
Thank you,
 S.
Bruno.Cossi
Re: Importing data from MS Excel
« Reply #1 on: March 22, 2004, 05:25:53 am »
You could certainly do it by opening the .eap file directly in MS Access (.eap file is an MS Access database) and importing the data into the t_requirements table.
If you use DB repository then use whichever tool you use for administering your database.
Does this help?
Bruno
« Reply #2 on: March 22, 2004, 05:40:03 am »
Hi sandi,
if you don't have ACCESS (like me) you could use a small VB macro to move data from Excel to Access via the jet engine. You will find examples on the internet how to do this.
Cheers,
Thomas
sandi
« Reply #3 on: March 22, 2004, 05:49:32 am »
Wow, thanx Bruno for a quick reply!
I've opened the eap file in MS Access. It seems, that I can't find the table named t_requirements even that I have quite a few of them (requirements) in the EA project (that is in this eap file). The closest name is t_requiretypes. :(
@Thomas: Great, thanx a lot! Will start looking right now for these examples. :)
Thank you guys,
 S.
Bruno.Cossi
« Reply #4 on: March 22, 2004, 05:51:59 am »
Hi Sandi,
sorry, my mistake - the table you need is called t_object. Look for the rows with Object_Type = 'Requirement'
Let me know if you need more help with this!
Bruno
sandi
« Reply #5 on: March 23, 2004, 01:58:10 am »
Hi Bruno,
I'm trying to copy/paste data from MS Excel into MS Access, t_object table, or even try to add any new record manually - no luck.
If I try to add a new record in this table, I get the error "Index or primary key cannot contain null value". Strange is, that this (index) field is autoincrement (AutoNumber),  therefore it should work, but it doesn't. :((
What should I do?
PS: I hope it's not related to other table dependency, t_attribute, t_package,...
Thank you very much for your help,
 S.
« Last Edit: March 23, 2004, 02:06:00 am by sandi »
Sean Kearon
« Reply #6 on: March 23, 2004, 03:23:43 am »
Would the CSV import/export facility do what you want Sandi?  I've never used it, just a thought really.  Right-click a package in the project explorer and go to Import/Export then CSV Import/Export.
Sean
Bruno.Cossi
« Reply #7 on: March 23, 2004, 05:17:45 am »
Hi Sandi,
yes, I forgot - it is related to t_package (column package_id). You need to put here id of a package into which you want to your requirements to be saved.
Bruno
Hi Bruno,
What should I do?
  S.
Bruno.Cossi
« Reply #8 on: March 23, 2004, 05:20:53 am »
Sean,
good point! I have forgotten about that as I have never used it myself - just looked at it and it seems like it could do the trick!
Bruno
Sean
Sean Kearon
« Reply #9 on: March 23, 2004, 05:34:47 am »
Nice one...now I understand what the feature is for from reading your thread :)
sandi
« Reply #10 on: March 23, 2004, 06:45:26 am »
Oh yeah! This one works perfectly. Thx Sean.
Another question, please. I'm using Keywords field for searching for certain string. Is this field ment for this or will I destroy something in EA if I use it for this purpose - can't find anything useful in help file.
Thank you again guys!
Rgds,
 S.
« Reply #11 on: March 23, 2004, 07:42:14 am »
This is what the help says:
Keywords -  A free text area that may be filtered in Use Case Metrics and Search dialogs - typically used for keywords, context information etc.
hth
Thomas
sandi
« Reply #12 on: March 24, 2004, 12:15:35 am »
omg,
I missed that. Don't know where I was looking - I found that under 'General Settings'.
ehhh, sorry for this one :(
« Reply #13 on: March 24, 2004, 03:58:26 am »
No matter - that happens to me also.
Cheers, Thomas
rvrivera
« Reply #14 on: April 14, 2004, 05:38:30 pm »
Is possible to import packages using a CSV import/export facility?
Thanks in advance.
Rubén
Sean
