Author Topic: SQL Server 2005 Beta 2 as Repository?  (Read 2671 times)
OwenJ
« on: August 09, 2004, 08:06:36 am »
Will SQL Server 2005 Beta 2 work as a repository?
OwenJ
Re: SQL Server 2005 Beta 2 as Repository?
« Reply #1 on: August 09, 2004, 08:58:18 pm »
I have created a database on SQL Server 2005 Beta 2 and ran the SQLSvr_BaseModel.sql script.  This executed without errors.
I then Upsized the base.eap model into this database without errors.
I am running into problems adding elements onto a diagram.  I receive the following error upon dropping the element....
"Microsoft OLE DB Provider for SQL Server [-2147217833]
String or binary data would be truncated."
After clicking OK on this message dialog box the element is added to the diagram and I am able to modify it.
This message also occurs when I save the diagram.
If the model is closed and re-opened all diagrams and elements are present.
I understand that this is a beta product and may not work correctly at this point.  Please let me know if you wish me to stop posting messages about this topic.  I am going to continue testing as this is the only database server I have available from this machine at this time.
Owen Johnson
Application Developer
Bandag, Inc.
Bruno.Cossi
« Reply #2 on: August 09, 2004, 10:44:45 pm »
Hi Owen,
I am much interested in your experiences with SQL Server 2005 - soon, we may have to deal with the same issue.
Thanks!
Bruno
