Author Topic: Stereotypes in RTF reports  (Read 7226 times)
Keith Bollwahn
« on: August 05, 2004, 11:46:02 am »
 ??? Prior to the release of 4.1 an object's stereotype appeared in my RTF reports.  Since upgrading to build 732 the no longer appear.  Does anyone know how to turn them back on?
johnr
Re: Stereotypes in RTF reports
« Reply #1 on: August 05, 2004, 10:56:43 pm »
It is possible that the Stereotypes are not appearing because in the Diagram properties (accessed by double clicking the diagram background) has in the Appearance Options, the Hide Element Stereotype checkbox selected.
If this is the case the option will suppress the display of the stereotypes.
I have tested this in build 733 and printing stereotype works fine.
Keith Bollwahn
« Reply #2 on: August 16, 2004, 01:25:58 pm »
I'm afraid this isn't what my problem is.  I'm not talking about the stereotype showing up in the diagram.  It's in the text of the RTF report.  Any ideas?
Jacques_Ronaldi
« Reply #3 on: August 18, 2004, 05:33:24 am »
Keith,
Stereotypes do appear in build 734 (I tested), not only in the diagram, but ALSO in the RTF export.
Please be more specific: are you referring to stereotypes not being shown in the "diagrams" of the RTF file, or in the class description of the RTF, or what?
I would suggest you do a simple test: create a new project, drop a class with a stereotype and test your RTF export: does it show? If so, then you might want to "recover" your original database which might be corrupted.
« Reply #4 on: August 18, 2004, 06:11:28 am »
Keith,
did you check Object Details? Without you don't see the stereotype. However, I second Jacques statement - be specific in what you did exactly.
