Author Topic: Requirements solution description  (Read 4200 times)
« on: October 19, 2004, 03:06:57 am »
Hi all,
I ran into a problem which I could not solve by myself: Often I have a set of requirements I pull out of a specification that need a certain answer. Name and Note for requirements are already used to capture the requirement itself. Now I want to describe the solution in more or less short terms. Once I'm finished I'd like to be able to gather all requirements and according answers to produce a "draft solution document". Does anyone have an idea how to do this best in EA?
CJ
Re: Requirements solution description
« Reply #1 on: October 19, 2004, 05:20:24 am »
G'day Thomas,
How about tags?
Cheers and best regards.
« Reply #2 on: October 19, 2004, 07:26:41 am »
Hi CJ,
I use tags for short answers (and I call the tag "Answer"  ;D). For longer descriptions I add a file reference where I also can place pictures. Somehow that works but it is awkward. I'm looking for a smarter solution.
sargasso
« Reply #3 on: October 19, 2004, 04:14:26 pm »
You betcha!  I am in the same situation.
I currently:
1. use element issues for the questions and answers.  2. Use file links back into the reqts spec to retain the "original" reference.
3. use a tag for the original reference paragrah/ heading/point number
4. Put the imported text in quotes at the front of the Notes.
5. Add pseudo tags around the original text to render html doc in italics/colour
6. Add the solution/clarification text below as a normal note.
Unweildy - nah!  ;D
But it does give me some control over the output - issues dont get lost as I can include them in rtf docs (and they are certainly visible in the html docs).
Where's Fluxtah and his request for formattable notes fields eh?
Bruce
« Reply #4 on: October 20, 2004, 01:15:30 am »
Hi Bruce,
fluxtah's last post is some 3 months ago. Hope he's back soon.
If you take element issues, I see two issues (;D) with that: First is that they are related to a certain element. Second you are quite limited in printing / exporting.
From my point of view it would be nice to have special file links which could be embedded via the RTF documentation. Currently I do that by myself using an awkward PERL script that extracts requirements recursively out of a certain tree location an mixes refenced RTF files under certain conditions. In that way I can produce a complete documentation which I can hand out to the customer. The disadvantage: very slow, buggy and the resulting RTF files are huge.
I'm really longing for improvements here  ::)
EDIT: Just found out that by adding #FILES# in the RTF template the associated files are printed. Maybe I could use a Word macro to actually include these files.
Btw.: Is there any documentation for #TEXT#, #FILES# etc. tokens?
« Last Edit: October 20, 2004, 08:31:56 am by thomaskilian »
Gabor
« Reply #5 on: October 25, 2004, 01:07:09 am »
I'm using the ordinary Issues element for questions and answers from my customers.
Put them into a Questions folder.
The issue name is the question (may be as long, as 110 char in three rows).
The answers I put into the note. If I got the answer, I change the status from proposed to the Approved, that changes the left sided column from yellow to blue.
I put these "Question" issues onto the requirements folder. If I got an answer, and think this is a requirement, I create a Requirement element, name it as requirement text, and add note as needed. Then create Realization dependency from the Requirement to the question.
I can color the requriements differently from the questions, to get a better look. For examle all requirements are pinks, all questions all yelows
If I create an rtf documentation on the question folder, that shows only the issues and object name, then I get all the questions, and answer, that I can send to my customers as needed.
If I create an Implementation documentation (Project/Documentatio/Implementation details...) on the question folder, I get all the questions, that became a requirement. If I create a dependency documentation on the requirement folder (Project/Documentatio/Dependency details...), I get, wich questions comprises the base of the requirements.
If I watch the requirement diagram, I visually see, how the questions are releated to requirements, and wich questions are answered, and wich of them not.
I can connect the question to any element, in any folder.
Morover, I can create subfolders for questions for speciale cases.
I can create rtf document for questions, created/modfied after selected date, so I can mail only the new questions to my customers.
This method works well for me.
Gabor
« Last Edit: October 25, 2004, 01:09:29 am by Gabor »
« Reply #6 on: October 25, 2004, 03:04:02 am »
Hi Gabor and Bruce,
thanks for your feedback. I'll try and see if this works for me  :)
If anyone likes to have my PERL-documenter I'm willing to share it (just drop me a private message). For the time being it's nearly undocumented but for real PERL freaks not really a drawback  ;)
« Last Edit: October 25, 2004, 03:10:30 am by thomaskilian »
