Author Topic: Where is the "paste diagram" menu item?  (Read 3701 times)
drdjibi
« on: January 17, 2005, 07:45:37 am »
I have a diagram in one project that I would like to copy into another project.  I've found how to "duplicate a diagram" in the manual which says to save or copy the diagram to the clipboard and then select "paste diagram" to make the copy.
I haven't been able to find any menu with a "paste diagram" entry.    What am I missing?
Re: Where is the "paste diagram" menu it
« Reply #1 on: January 17, 2005, 02:45:06 pm »
Create a new diagram, open it, then Ctrl+V.
HTH  :)
drdjibi
« Reply #2 on: January 17, 2005, 03:18:11 pm »
Yes, I should have mentinoned that I tried that, but it pasted a bunch of classes into the new diagram--none that were in my original "copied" diagram.
drdjibi
« Reply #3 on: January 17, 2005, 03:31:39 pm »
Actually, when I "pasted elements" from the edit menu is when the incorrect classes were pasted.  If I use "crtl v" it says "An error occured locating the required object."
« Reply #4 on: January 19, 2005, 12:40:57 am »
What do you mean by "another project"? Is it another repository or another (root) package?
« Reply #5 on: January 19, 2005, 01:19:24 pm »
If by project you mean an EAP file (or database repository) then you'll need to use XMI export on the package containing the diagram you're wanting to copy.
Simon
drdjibi
« Reply #6 on: January 19, 2005, 02:37:03 pm »
Yes it was a seperate EAP directory and I was able to succesfullly export/import the diagram.  Thanks
