Author Topic: How to use RTF linking/bookmarks  (Read 3816 times)
davisford
« on: February 22, 2005, 09:23:50 pm »
Hi, I am trying to understand the feature described in the Zicom Mentor for creating formal documenation by exporting various packages as RTF, and then inserting them as links into a master template document.
I have a template doc, and I export a particular package to a new RTF file (e.g. use_case.rtf).  Then, within the master template, I choose Insert->File, and navigate and pick use_case.rtf.  This inserts ok, but it is not really linked, as far as I can tell.  If I change the use case model, and re-export a new use_case.rtf, these changes are not updated in the master document.
I then tried right-clicking on the use case package in EA, choosing Documentation->Copy RTF Bookmark to Clipboard.
Then in the master template, I choose Insert->File, navigate and pick use_case.rtf, and then click Range... button and paste in the RTF bookmark.  This does not change the behavior.  If I update and re-export use_case.rtf, the change is not reflected in the master template.
Is there a way to synchronize this / automate it -- or do I need to re-insert RTF's after every change and export to RTF for the master template document?
Thanks in advance,
Davis
Tjerk
Re: How to use RTF linking/bookmarks
« Reply #1 on: February 23, 2005, 06:54:02 am »
Open your Word master template in Outline view (see View menu), then select Import Subdocument from the Outlining toolbar.
davisford
« Reply #2 on: February 23, 2005, 08:17:13 am »
tjerk -- thx.  got it.  works.
