Author Topic: Fail to import XMI File into EA  (Read 3725 times)
christo
« on: May 03, 2004, 05:16:54 am »
Hi all  :)
I have exported a visio diagram as an XMI file.  With the UML.DTD file placed in the same directory I tried to import the XMI file using the appropriate IMPORT function but received the following error
Error: Code = 0xc00ce00d
source=line :12; char : 80
Error Description =
The element 'Model_Management.Subsystem' is used but not declared in the DTD/Schema
Any ideas? :-[
I shouldnt be creating my own UML.DTD file should I as I am using one passed onto me from a co-worker who got the file from Microsoft (I think)
Thanks for your help in advance ;D
Chris McKelt
Re: Fail to import XMI File into EA
« Reply #1 on: May 03, 2004, 06:26:31 am »
Try the DTD distributed by Sparx. This one contains a section by that name.
christo
« Reply #2 on: May 03, 2004, 08:20:21 pm »
Thanks Thomas
Where abouts is that file located on this site?
;D
« Reply #3 on: May 03, 2004, 11:24:14 pm »
Good question though. I have a version on my disk that I called UML_EA.DTD to distinguish from the Rose version I had. I can't recall where this version came from. But anyway, I can send it by mail if you send me your e-mail address.
christo
« Reply #4 on: May 04, 2004, 01:14:21 am »
I have a UML_EA.DTD created from exporting the EASample project  but this didnt work unfortunately.
Anyone know of anyway to get the UML.DTD exported from visual studio?
Maybe I could try yours if thats okay my email address is chrismckelt AT multiskilled.net
Thanks again for your help Thomas I appreciate it very much  :D
Wivel
« Reply #5 on: March 31, 2005, 06:11:01 am »
Hi
I am having the same "subsystem" issue here, and also need help resolving it.
I am trying to export from Visio and import into EA ver. 4.51.
Can anyone help with an updated/changes DTD file?
Regards
Henrik Wivel
« Reply #6 on: March 31, 2005, 07:34:56 am »
Sorry - too long I go. As far as I remeber the problem was not solved by the other DTD :'(
