Author Topic: Mutiplicity default adornment settings  (Read 3410 times)
« on: April 18, 2005, 01:54:38 am »
If you right-click on a multiplicity object, you see a number of context menu options; two of which are:
  • Default Positon
  • Default Color
Where can I set these defaults for the machine \ project \ package \ diagram?
Re: Mutiplicity default adornment settings
« Reply #1 on: April 18, 2005, 06:10:18 am »
What is a "multiplicity object"?
« Reply #2 on: April 18, 2005, 07:30:34 am »
The little text object that displays the multiplicity (located at the ends of the association on a diagram).
« Reply #3 on: April 18, 2005, 03:43:34 pm »
I don't know about setting those defaults, but those options restore the defaults (which I assume are built in to EA.)
See http://www.sparxsystems.com.au/EAUserGuide/index.html?labelmenusection.htm
Simon
« Reply #4 on: April 18, 2005, 05:52:50 pm »
Thanks Simon,
But I did realise that they would reset the defaults.  My questions was specifically where are these defaults set, if they are settable;  and if not, why not?
« Reply #5 on: April 18, 2005, 06:59:02 pm »
Sorry, I misunderstood your original question.
Neither can be set, as why not.  I didn't make the decision, but the position is an offset to the default.  If a default was settable then it would likely result in more messy diagrams as not all links attatch to classes from the same direction, as a result the multiplicity of the link could end up inside the class or something like that.
I don't see a good reason why the default colour isn't settable, except for consistancy...
Simon
« Reply #6 on: April 18, 2005, 08:24:46 pm »
I can live with not being able to set the default position (for now ;D).  But I think the other attributes - Font and Colour ought to be settable as defaults by the user.
