Author Topic: Element feature attached notes  (Read 2805 times)
« on: April 18, 2005, 10:41:14 pm »
Element feature attached notes are magic! 8)
However, since they are attached (and therefore derived), EA quite correctly inhibits you from editing them on the diagram.
It should also "gray them out" in the Notes tab of the Notes window (usually below the browser) to indicate the same concept.
It would be nice if there was a little graphical indication that it was linked.
Finally (for now at least) the Note Properties context menu item should be disabled.
dserodio
Re: Element feature attached notes
« Reply #1 on: April 19, 2005, 10:47:00 am »
Yeah, a graphical indication that it's a linked feature would be nice.
Correctness is clearly the prime quality. If a system does not do what it is supposed to do, then everything else about it matters little. - Bertrand Meyer
