Author Topic: Find and Replace  (Read 3132 times)
lad4bear
Find and Replace
« on: May 06, 2005, 05:35:43 am »
Hi Guys,
Another simple question from the new guy.
How do I find and replace across the whole of my use-case model. i.e change actors names in my use-cases scenarios.
Currently, I can Edit->Find to locate them but am having to make the changes by hand.
Cheers, Pete (aka lad4bear)
Re: Find and Replace
« Reply #1 on: May 06, 2005, 09:22:50 am »
You might go directly to the database :-/ Check out t_object
lad4bear
« Reply #2 on: May 06, 2005, 09:56:45 am »
lol ... sounds a bit scary that does. still, i'll look in to. thanks
Pete (aka lad4bear)
« Reply #3 on: May 06, 2005, 11:12:10 am »
Not too scary - more awkward. Once you got used to it ;D
« Reply #4 on: May 06, 2005, 04:31:13 pm »
Agreed, not too scary when you get used to it...  Had to resort to it yesterday, myself.  But you shouldn't have to! ::)
Search and Replace is a REALLY important function for maintaining model .... .... .... consistency! ;D  It should be a standard function!
In addition, using the DB you can still miss stuff.  Whereas a properly implemented UI function (with automation tie-in) will get ALL the occurrences.
Put in an enhancement request...
lad4bear
« Reply #5 on: May 06, 2005, 05:42:32 pm »
Sure will  ;)
