Author Topic: Bug in auto doc generation templates?  (Read 3878 times)
wink
  • Montjoie, que jamais ne choit!
« on: April 20, 2005, 08:23:53 am »
Hi evereybody,
I just experienced a strange behavior while using the auto doc generation templates which seems like a bug to me, however I might have done something wrong.
Here is what I'm doing. ???
- select a package "A" in the browser
- Hit F8 (generate documentation dialog)
- select a template "TemplateA" via Template|Load
- press "Save as Document" button and name it "AutoA" and click OK.
- press cancel in the "Rich Text Format Dialog" in order to select another package in the browser
- select a package "B" in the browser
- select a template "TemplateB" via Template|Load
- press "Save as Document" button and name it "AutoB" and click OK.
Now I go to the resource view in the browser and select the RTF document "AutoA" and celect "Generate Document..."
I get into the "Rich Text Format Dialog" and see the package "A" that is correctly selected BUT the TEMPLATE is the one for package "B" (TemplateB) instead of the one I saved togeter with A (TemplateA).
I would appreciate if someone could enlight me if I'm doing something wrong or if this is a bug.
Thanks in advance,
best regards
Manfred
Best regards,
Manfred
michael_rainwater
Re: Bug in auto doc generation templates?
« Reply #1 on: April 21, 2005, 02:44:20 pm »
I have encountered the same issue.
What I've done about this, is to use the "Save as document" feature.  Read more about this in Help under the contents:
Creating Documents
 -> RTF Documents
   -> The RTF Dialog
     -> Save as Document
I use this as a way to setup what I want to generate and associate the template.  Then, I can right-click a use the "Auto-Generate" feature on this resource it creates.
This seems to work well.  I only wish there was an "Auto-Generate All" button.
wink
« Reply #2 on: April 21, 2005, 11:24:32 pm »
Hi Michael,
Thanks for the reply!
You mean that it works when you select "AutoGenerate" instead of "Generate..." ?
Best regards,
Manfred
michael_rainwater
« Reply #3 on: May 02, 2005, 05:29:49 pm »
I don't think I read your first post correctly.  I see you are using the "Save as document" feature.
I just went through the steps you describe and my template is associated correctly.  In fact, I count on this working for my doc generation.
I can't get it to error like you describe.  Perhaps because I am using Build 751.  Which build are you using?
wink
« Reply #4 on: May 02, 2005, 11:43:57 pm »
Hi Michael,
Thanks to your mail I tried "Auto Generate Document..." instead of "Generate Document..." and it works correctly.
However when I use "Generate Document..." the template in the "Rich Text Format Report "dialog is not the one I associated with the document.
So I think there is only a bug in "Generate Document..."
Thanks for your support!
PS: I'm using version 4.51.750 Build (750)
Best regards,
Manfred
wink
« Reply #5 on: May 10, 2005, 01:56:04 am »
Hello Michael, everybody,
I just received my registration number and downloaded the full version.
Good news: The "bug" is gone!!! :D
Everything works well now.
I thought I let you know.
Have a nice day,
Best regards,
Manfred
