Author Topic: Import DDL: MS Access works in 4.51 but not in 5.0  (Read 3231 times)
matthias
« on: June 22, 2005, 09:51:59 am »
What I would like to do:
- register any *.EAP file as an ODBC-source (MS Access) on your machine
- import DDL from this ODBC source
With EA 4.51 this works fine, but not with 5.0. The result is a system error, EA crashes.
(The error seems similar to the DDL import from a MySQL database - in this case EA also crashes - both 4.51 and 5.0)
sargasso
Re: Import DDL: MS Access works in 4.51 but not in
« Reply #1 on: June 22, 2005, 04:57:24 pm »
Works fine for me - ver 766.  Check your MDAC version and the corresponding use of MDAC by EA.  There have been other posts of this inkling, I beleve they were tied in with say trying to use a JET 3.5 .eap on a machine with "Jet 4.0" MDAC.  IOW, the ODBC drivers are expecting a Jet 4 access image and the EA image uis 3.5
hth
bruce
matthias
« Reply #2 on: June 23, 2005, 01:33:15 am »
I have a standard XP machine - and I did not changed the system regarding MS Access or ODBC drivers. What I changed is the EA version.  So the problem seems to be a change in EA from 4.5 to 5.0 ?!
May be this screen shot gives more information:
http://www.maennerchor-dorfen.de/users/web128_bleyl/fehler.jpg
What ever the problem is - a more meaningful error message would be nice.
sargasso
« Reply #3 on: June 23, 2005, 04:24:36 pm »
I quite agree.  I will forward an email to Bill forthwith.  (Its a windows message  :)  )
« Reply #4 on: June 24, 2005, 01:27:19 am »
Although it's a windows message, it is due to an uncaught error in EA. Probably you should forward this to Sparx support?
