Author Topic: Oracle 9i Repository  (Read 3298 times)
JeffM
« on: October 26, 2005, 07:01:59 am »
New user of EA Corporate and ony just getting started... Went through ICONIX training but this topic just never came up.  I have a couple of questions that I was hoping someone could/would answer, please.  I can't find any definitive info on these in EA Help or through seraching the BB.
1.  Why is [or is it?] a repository better than just using the .eap file?  fyi - There will be multiple users accessing this at any given time.
2.  Can one repository be used for multiple projects?  Safely?  Where there would be many projects and many users accessing each of these projects simultaneously?
Thanks for any input/feedback.
Jeff M.
Oliver Michalski
Re: Oracle 9i Repository
« Reply #1 on: October 26, 2005, 07:27:35 am »
Hi Jeff,
i only can answer the first question. The eap- file is the same as a Microsoft Access Database . Microsoft Access doesn't support multiple user access. If you work in a team use a repository.
Oliver  ;)
« Reply #2 on: October 26, 2005, 08:56:40 am »
To answer you 2nd question: A repository is as save as the underlying database. You can store multiple projects in the same repository when you use different roots in the project view. This has dis/advantages depending on your needs. You would likely need EAs security instead of using the database's mechanisms.
hd
« Reply #3 on: October 26, 2005, 03:40:08 pm »
JeffM
« Reply #4 on: October 27, 2005, 07:47:43 am »
Thank you all - this has been very helpful.
