Author Topic: Logical View - Hide Data Type?  (Read 6848 times)
JulianH
« on: November 06, 2005, 01:39:22 am »
Hi There. I'm currently modelling a database wirh EA. Actually, right now, I'm modelling an ERD with the Logical View "Feature".
I always inserted a data type with every attribute in a table, but now I want the chance to hide the data types (so that there are only the names of the attribute in every table visible - I don't need any data type in an erd - that's overhead ;) ) I mean, I want the data types stored for every attribute, but I don't want them visible in the model.
How can I do this?
Julian
jeshaw2
Re: Logical View - Hide Data Type?
« Reply #1 on: November 06, 2005, 05:31:12 am »
Julian;
Right click on the diagram element representing the table.  Select Features -> Feature Visibility Then in the Attribute Visibility panel, uncheck "all".
Hope this is what you wanted.
« Last Edit: November 06, 2005, 05:32:19 am by jeshaw2 »
JulianH
« Reply #2 on: November 06, 2005, 05:45:39 am »
Julian;
Hi jeshaw2.
It's not exactly what I wanted.
I will explain it more in detail:
- I have a table (lets say: City)
- There are attributes (lets say: Name, PostalCode, ..)
- This attributes have data types (Name has NVARCHAR2, PostalCode ..lets say LONG).
CITY
Postal Code : LONG
^--- that's what the table looks right now.
I want the table to look like this:
CITY
NAME
Postal Code
See the difference? There should be no more data types :) I don't want to delete the data types for every attribute manually, because I need them afterwards. But I want to exclude them from being shown :) Is there a chance to do so?
Julian
« Reply #3 on: November 06, 2005, 08:59:34 am »
You can also hide visibility by using different stereotypes.
Bruno.Cossi
« Reply #4 on: November 06, 2005, 10:11:39 am »
That won't help, Julian does not want to hide the attributes altogether, only their data types. I think there was a discussionabout this a while back with the conclusion that that was not possible, but that has a been a while back and EA has evolved since then. Not sure if it can do this though :-)
Bruno
JulianH
« Reply #5 on: November 06, 2005, 10:18:22 am »
Bruno
Hi Bruno.
I didn't find a menu entry that can do that. Maybe I didn't look that much, but there was no feature that could hide the "Attribute Domains".
Julian
Bruno.Cossi
« Reply #6 on: November 06, 2005, 12:14:20 pm »
Hi Julian,
I think you are right, this probably can't be done with the current version of EA. Definitely worth submitting as a feature request though!
Bruno
Hi Bruno.
Julian
JulianH
« Reply #7 on: November 06, 2005, 12:31:37 pm »
Hi Julian,
Bruno
Hi Bruno. Yes, this would be fine. It can't be a big deal for the developers to implement this feature. But I think it would be a great advance for all of the users, because sometimes everybody needs this feature :)
(i guess)
Julian
jeshaw2
« Reply #8 on: November 07, 2005, 04:36:47 am »
When you add an attribute to a class, in the Properties window you can see the type field.  In my version of EA (771), a default type of "int" is entered.  Delete the value in that text box and it won't show on the diagram.
Bruno.Cossi
« Reply #9 on: November 07, 2005, 04:43:57 am »
the point is not "not to have a data type" but to have a data type, but not display it on the diagram.
Bruno
