Author Topic: Re: UML 2 component wiring  (Read 9366 times)
« on: October 11, 2005, 05:57:41 am »
Not sure whether I got you right, but you can layout these connectors as any connector in EA. That is: use a lines style or bend at cursor position (both in context menu, latter also by ctrl-click).
nya
« Reply #1 on: October 11, 2005, 06:28:52 am »
Thanks Thomas. Appreciate your response.
Ok I was looking for the assembly connector, and I didn't notice the dropdown arrow on the component toolbox.
cheers
« Last Edit: October 11, 2005, 07:31:57 am by nya »
nya
« Reply #2 on: October 11, 2005, 07:00:08 am »
I guess I'm looking for the assembly connector to do this. But I can't seem to find it in the toolbox
« Reply #3 on: October 13, 2005, 12:33:08 am »
Look in the Composite tab of the toolbox. Right in the middle.
nya
« Reply #4 on: October 13, 2005, 02:35:23 am »
Thanks Thomas!
best
Nya
sergeys
  • hmmm
« Reply #5 on: November 09, 2005, 08:49:00 am »
Hi!
I'm using EA 5.0 (Corporate Edition) and I fail to find the Assemby connector in the Toolbox. I don't see the Composite tab either.
Please, help!
nya
« Reply #6 on: November 09, 2005, 09:21:09 am »
Hi sergeys
It is just a design 'feature' of EA.
There is an arrow under the Composite tool box - only it looks like it belongs to the toolbox below, Communication. Click on the arrow, and le voila, the assembly connector appears  ::)
sergeys
  • hmmm
« Reply #7 on: November 09, 2005, 09:28:09 am »
Hi!
Thanks for the try, but what I see is anything but not the "Composite" toolbox.  I have "Structure" and then "Communication" comes below. No "Composite".
What version of EA do you use? Mine is 5.00.769.
Should I upgrade?
sergeys
  • hmmm
« Reply #8 on: November 09, 2005, 09:33:55 am »
The issue is closed - found myself  :).
There's a way to add/remove/customize toolboxes via Tools\Options\UML Element Toolbox.
For some reason, the Composite toolbox wasn't checked there...
Anyway, thanks!
