Author Topic: painter tool EA 6.0  (Read 8577 times)
rescobar
  • Viva Bolivia
painter tool EA 6.0
« on: November 16, 2005, 06:41:49 am »
Where is the painter tool? I can't copy appearance because I can't find this tool that I used to use.
Tks for your help.
Ramiro
Sergio Escobar
Re: painter tool EA 6.0
« Reply #1 on: November 16, 2005, 06:50:14 am »
I just went through a bug report and found the reason. The painter symbol in the top task bar is "Apply Style" from the Format Tool. The painter is in the Diagram toolbar. Both have the same appearance :o
rescobar
  • Viva Bolivia
« Reply #2 on: November 16, 2005, 07:12:01 am »
I think we have a bug there. My format tool does not appear even I check/uncheck/check again in the View/Toolbar menu.
Sergio Escobar
rescobar
  • Viva Bolivia
« Reply #3 on: November 16, 2005, 10:15:39 am »
I found it. The thing is that the format toolbar appears in the down side of the screen.
We indeed have there the painter tool but is not running at least as used to work in the 5 version.
I used to Appearence/Copy Appearance to Painter the element I want to copy to and then apply the Painter tool to the element chosen.
Maybe am I am using the wrong procedure?
Sergio Escobar
« Reply #4 on: November 17, 2005, 02:43:36 am »
What does the quick help say, when you hover over the icon?
rescobar
  • Viva Bolivia
« Reply #5 on: November 17, 2005, 04:00:57 am »
"Apply Style"
By the way, this procedure works well in EA 5.
Sergio Escobar
« Reply #6 on: November 18, 2005, 02:36:12 am »
Apply Style is the wrong Icon! Activate the Diagram Toolbar (uncheck/check to see which is the right one). It also contains a Painter telling "Paste Appearance" which is the one you need.
This is under investigation at Sparx.
rescobar
  • Viva Bolivia
« Reply #7 on: November 18, 2005, 04:06:01 am »
You are the one!
The rigth icon is "Paste Appearence".
Anyway, It's confusing, isn't it?
Thank you very much.
Ramiro
Sergio Escobar
