Author Topic: code engineering bug  (Read 3179 times)
mschipperheyn
« on: December 19, 2005, 04:59:32 am »
I had some weirdness with code generation. I generated code, then made some changes to the UML. Then engineered the code again.
Even though the generated files were date marked correctly to mark the changes, some changes I had made in method signatures weren't reflected. They were only reflected after I deleted the source code and re-generated.
Marc
woodz
Re: code engineering bug
« Reply #1 on: December 19, 2005, 12:41:32 pm »
I've also made that experience.
I've solved it for me like this:
- do modifications on memberfunctions (names and parameters) or attribute renaming  in the IDE (e.g.VC 2003)
then reengineer the class(es)
- adding new members works as well as adding new classes, simple forward engineering should be adequate
I don't understand, why big IDEs like VC 2xxx .NET do not come with a fully intergatet UML 2.0 tool like EA?
How do the big developers, like sparx, softwareengineering? Forward/backward? I can't imagine.
« Reply #2 on: December 19, 2005, 02:09:32 pm »
Hi Marc,
What language were you generating?  What changes did you make?
If you're changing method names and/or parameter types you'll probably want to enable prompting.  (Tools | Options | Source Code Engineering | Attribute/Operations | On forward synch, prompt to delete code features not in model)
Or alternatively enable live generation for your working package.  (Project | Build and Run | Package Build Scripts | Use Live Code Generation)
mschipperheyn
« Reply #3 on: December 20, 2005, 12:53:29 am »
I was generating Actionscript
Marc
