Author Topic: Build 781 - Table Attributes on Diagram  (Read 2256 times)
Dana_Maxwell
« on: January 03, 2006, 12:23:24 pm »
I've installed 6.0.781.
When I view my class diagram, my table attributes are ordered alphabetically. Order is maintained on the attribute dialog but not kept consistent on the diagram. Is this a bug or did a default setting get changed?
I tested accessing the same model with our previous version (5.0) and it worked fine so it is definitely something that happen in the upgrade to build 781.
Please let me know if there is a setting I can change or if a new build is required.
Dana
hd
Re: Build 781 - Table Attributes on Diagram
« Reply #1 on: January 03, 2006, 02:07:46 pm »
You can set the sort order as follows...
Tools | Options | Objects | Sort Features Alphabetically (check box - bottom left).
Dana_Maxwell
« Reply #2 on: January 03, 2006, 05:51:43 pm »
Sweet.
Dana
